Hi I have bought the VMS4 recently, and I have some issues with the controller.
I tried to do like on the guide of the VMS4 posted by djdad, but it doesn't work properly.
I have 2 big problems :
1. When I play a song on deck 1 of VDJ, the fader of midilog 2 works ok. But when I touch the fader of midilog 3, the sound of deck 1 is changed. Same thing with deck 2 of VDJ and midilog 2. I see on the screen the fader moving when I move fader of VMS4. When I move the fadder with the mouse only on VDJ it works fine (moving fader of deck 2 doesn't change the volume of deck1)
2. headphones problem : i cannot have the headphone out work properly. I only listen the master on the headphones.
Thank you for your help.
If someone can give me the configuration of Asio Driver and Sound settings of VDJ, it will be very apreciated.
Al
Al
Posted Sun 13 Mar 11 @ 10:14 am
Please HELP
Posted Mon 14 Mar 11 @ 9:14 am
Al
Al
can you post a screenshot of your advanced config settings?
with headphones are you using the cue buttons on the VMS4 and the knob for cue mix on front of the VMS4?
Posted Mon 14 Mar 11 @ 9:59 am
Hi.
I managed to fix my first problem (using external mixer as output audio configuration)
but I still have the headphones issue.
My settings :
Asio Config :
midilog 2 Out 1 Out 2
midilog 2 Out 3 Out 4
VDJ Audio Config : none/external mixer/asio
External Mixer config : deck 1 Out 1&2 / deck 2 Out 3&4
So now the controller works fine.
But I still have my headphone problem. I mean I can only hear the master sound on my headphones.
I am using the cue buttons on the VMS4 and the knob for cue mix on front of the VMS4 to control headphone
Thanks for helping
My settings :
Asio Config :
Thanks for helping
Posted Tue 15 Mar 11 @ 7:19 am
