I have VDJ 7, I downloaded the timecode cds but cant get the timecode config to work. The picture only shows a square instead of a circle. I tried adjusting all the settings in the time code but still at "Quality 0%" what do i need to do?????
Posted Wed 09 Mar 11 @ 4:07 pm
Unplug everything and check your needles then reconnect everything back up. Make sure all your wires and ends are good.
Huey
Huey
Posted Wed 09 Mar 11 @ 4:35 pm
DjDestruct wrote :
.......downloaded the timecode cds......
You probably need brand new needles to read these ;)
If you have green squares istead of circles your signal is way to loud. Go to "Timecoe config" and turn your gain down. Also check under the "debug"-option that "RIAA-correction" is unchecked. You don't need that with CD's.
Posted Wed 09 Mar 11 @ 4:46 pm
