Yes it has a few bugs which are easily worked out. I am just making the switch to technology...lol. VDJ Pro is great for anything you need. Even if you get a two deck control the skins work you through it. I use a 4 deck out of necessity but don't regret it a bit. I know there are a lot of Traktror and Serrato fans and I tried them all before I went with VDJ Pro. Get the right control and to get VDJ Pro for $150.00 is a steal.
Posted Wed 09 Mar 11 @ 11:49 am
If you share what they are we can maybe help. VDJ7 is pretty much bug free IMO
It's only $150 if you have a rebate from a console version. If you don't have that then the retail price is $300
Keith
Posted Wed 09 Mar 11 @ 11:52 am
Yeah sorry I thought I threw the console part of the rebate in there, but there is a console for everyones needs that comes with VDJ7. With pro I haven't had any problems. With VDJ Basic I uninstalled everything. The RMX Drivers and the VDJ software. Then reinstalled it with the same updates that would not work when I originally installed it. Hope this helps.
Posted Wed 09 Mar 11 @ 1:59 pm
