Is there any way to stream a Visualizer that goes with your songs so that you could VDJ while you DJ your audio. Or, even better, is there a way to connect your audio to another PC (or laptop) so that you (or someone else) can VDJ on a separate device??
Posted Mon 07 Mar 11 @ 9:01 pm
*bump*?
Posted Tue 08 Mar 11 @ 12:02 am
Please don't bump posts, especially not something that is only 3 hours old.
VDJ supports Sonique visualisations, and there are solutions for Flash and Milkdrop too.
As for sending the audio to another PC, yes, you could just use an audio cable.
Posted Tue 08 Mar 11 @ 4:54 am
I know that but I was saying sending audio to the other PC and have them run a visualizer
Posted Tue 08 Mar 11 @ 2:43 pm
Yes. Plug an audio input from either your mixer, or an output on the line in on your soundcard into the other PC.
If you're talking about over the network then yes it's possible, but it would have to be done outside of VDJ. It's not really a function that VDJ should look at providing, since the application on the other PC would have to decode it.
Posted Tue 08 Mar 11 @ 4:37 pm
perfect! thanks a bunch dude!
you mentioned Sonique visualisations. is there a place I can Download that or something?
Posted Tue 08 Mar 11 @ 8:07 pm
Plenty available on the internet. Be careful as some sonique visualisations do funny things if they don't detect winamp running etc.
A tested and verified pack is available to registered pro users.
Posted Wed 09 Mar 11 @ 3:14 am
AWESOME!! again, thx a bunch for the help
Posted Wed 09 Mar 11 @ 1:59 pm
Hey guys. I know this a little unorthodox but like most of you, I lack the funds to upgrade to VDJ pro unfortunately. I was wondering If anyone knew of any third party software that can connect to the audio played in VDJ and output a nice audio visualizer. This is of course a temp solution until I can get VDJ pro and get the plug-ins.
plox n thx
plox n thx
Posted Wed 09 Mar 11 @ 7:56 pm
