Topic: [NEW] VirtualDJ 7.0.3 released - Page: 5
Plugins, tools, skins and so on are for licensed users only I'm afraid.
Hi i just installed the new Virtual dj LE v7 for my mixtract pro. so first when i plug in my mixtrack pro to the usb,it lights up,when open the vdj le v7 software, the light goes of and there no connection held between the software and mistrack pro why?
I recently installed the update VDJ LE 7.0.3 and all of a sudden my mixtrack pro controller does not seem to work. All the lights come on for a few seconds then cut off. It works fine on the home version
can anybody give me serial number for licence please
No one from this site will post or provide you a license. If you would like a license then you need to purchase one - https://virtualdj.com/buy/
Hi all, I'm completely new to the VDJ software, is there anywhere I can get like a manual or somet?
cheers
cardandrewdj wrote :
HELLO
I have a problems with my VMS4
the new version download Virtual dj 7.0.3
The LOOP in, out, beloop, loop does not work on VMS4
Do you have too a problem too ?
YES! i found out the hard way, my loop works but at random times it will ditch the audio on the deck being looped!! hitting cue or stop fixes it! bad bug there with the vms4
jakovski wrote :
djnands wrote :
Hi guys,thanx for update,after all those updates,
i just dont understand why FADETOBLACK is still on volume sliders????????
You realy think its not important for vdjs to have DECKS_VIDEOFADER???? Just like VIDEO_CROSSFADER?
Can you TEAM,please give me a clear answer?
If you did not like this feature - you can deactivate it in your Configuration / Video tab.
Greets, Heiko
hi jakovski,
You really think that,if i didn´t like this feature i would spend my time asking for it since 2009? 2 years now :)
Perhaps you didn't understand what i meant
have you read this treat:
https://virtualdj.com/forums/109291/Wishes_and_new_features/deck_s_video_fader.html?page=1
I have already tried the new SBDJ Videofade plugin,and it does not make the job,even SBDJ said it doesn´t
So for all VDJ TEAM,guys I BEG YOU,it´s very important to overcome this issue for video mixing or even audio mixing(using video effects like camera or clipbank,etc)
i love this software,but i still cannot use it as i´d love to,and if i wasn´t clear again,should a make a new video explaining the issue again?
