...ok thanks...i will do that when i get home...i reinstalled VDJ last nite to no avail...to answer your question i am using vista premium home edition 64 bit sp2....
Posted Thu 10 Mar 11 @ 6:33 pm
adamjmeek wrote :
...wtf....? ok first things first--when i go to the config panel in VDJ and select Rmx as the soundcard it will not allow me to check the apply EQ box--its a ghost box...
This is indeed the case with VDJ 7.
- If an input source (MIC, Line In, TT) is selected, VDJ is required to use ASIO, so it switches the Rmx automatically. In this case the box "Apply EQ..." is greyed out since the Rmx is already in ASIO.
- If no input source is selected, then the box is avilable, allowing you to select if you want to use WDM or ASIO
adamjmeek wrote :
second--when i select mic as the input in the Rmx control panel it switches to line in when i open VDJ...
Again, a VDJ particularity to default to LINE In on startup. You will need to switch to MIC in the control panel after VDJ as been launched.
Not sure if this is a bug or by design.
adamjmeek wrote :
third--when i try to apply the Rmx as the soundcard in VDJ i get the ASIO error message..........this is SO frustrating...any help is appreciated...
Normaly, Once you audio configuration is applied, when you close VDJ, it should remember it and use it upon the next time, given that nothing has change. However, if you you were to use VDJ with the internal sound card of your computer in between 2 sessions with the Rmx, then the audio configuration would have changed, making VDJ display this error.
Posted Fri 11 Mar 11 @ 6:21 am
...cool thanks man...i will go home and try it this evening--i appreciate your input...in the meantime i have been using the guitar in on my drum machine for the mic...
Posted Sun 20 Mar 11 @ 8:47 pm
adam try this open your control panel on your laptop, then open hercules dj series (be sure rmx is connected) turn on mic then exit. that should work
Posted Tue 22 Mar 11 @ 8:57 am
