I have heard good and bad. The best advice is to find a store that sells it and go get a hands on feel before you purchase. Maybe exactly what you want or you may think it's not. Ive never had one so I have no opinion. If you want to know the truth at the store look at a more expensive one. You will truly find out about the one you want if you tell them its between them two and they send you the message to get that one.
Posted Wed 09 Mar 11 @ 2:11 pm
Thanks, that's some good advice. That's what I'll do!
Posted Wed 09 Mar 11 @ 3:41 pm
