I just recently bought the IDJ3 and I want to create a folder that contains a playlist of songs. I want to arrange the songs so that the bpms match up and work together but I'm not able to move the songs up or down in my playlist, they just go in order they were dragged into the folder, any help?
Posted Tue 01 Mar 11 @ 11:24 pm
What you do is open VDJ and drag songs from your database to your playlist on the right. Once you're happy with the order your songs are in click on the icon in the upper left corner of the playlist under the automix button (looks like a sheet of paper) and click "save'. Name your playlist.
It will then show up in the left browser window under the 'playlist' tab.
Hope that's what you're looking for.
AC
AC
Posted Wed 02 Mar 11 @ 3:15 pm
thanks for the help man....when i drag them from my list of songs to the right, it puts them in the order i drag them, wont let me move any of the songs up or down. I don't see anything in the upper left, maybe i have a different version of virtual dj, it should be the newest since i just bought it. i haven't upgraded to pro yet, im not sure if that makes a different.
Posted Wed 02 Mar 11 @ 11:20 pm
Does that explain it better?
Posted Wed 02 Mar 11 @ 11:28 pm
Yeah man mine dont have that option to select, must have to get pro. I tried to print screen mine but i couldnt do that either haha im on a roll right now.
Posted Wed 02 Mar 11 @ 11:36 pm
Your batting a thousand right now! What version of the software are you using?
Posted Wed 02 Mar 11 @ 11:39 pm
I just upgraded to pro and NOW i can see what your saying and it lets me move my songs around.......that should be what I was looking for! Thanks man!
Posted Wed 02 Mar 11 @ 11:42 pm
Make sure you register your software! Welcome to the community.
Best of luck
Best of luck
Posted Thu 03 Mar 11 @ 12:27 am
