Hi everyone!
i am an old school bedroom dj; perhaps not that old school since I recently switched to cdj200 from technics 1200. My set up is 2 cdj200, vestax pmc46 rotatory mixer, sony mdr 7509 headphones and a laptop.
After reading and googling, I understand that I need a sound card to connect my dj set up to virtual dj. May I ask for your recommendation of which one sound card I should be buying? I have a budget of 100 dollars? so far I know may 44 and and Native Instruments AUDIO 2 DJ Interface could be the one I should buy.
Any info on how to connect the system to virtual dj? what cables should I need? I don't mind doing some reading. Any feedback please?
thank you all! K
Posted Sun 27 Feb 11 @ 2:44 pm
Run Your Input From Your CDs In And The Out Put From The 44 Goes To Your Mixer 1L&R 2L&RMay Sure You Download Your Drivers And Alway Use The same USB
Posted Mon 28 Feb 11 @ 10:49 am
Run Your Input From Your CDs In And The Out Put From The 44 Goes To Your Mixer 1L&R 2L&RMay Sure You Download Your Drivers And Alway Use The same javascript:showpic(\'http://www.esi-audiotechnik.com/pictures/maya44usb_large.jpg\');
Posted Mon 28 Feb 11 @ 10:53 am
thank you asthedj for your time. it looks like maya44 is the one I'll be buying.
thanks!
Posted Tue 01 Mar 11 @ 9:56 pm
