I'm a beginner and I recently purchased a Numark Mixtrack Pro and it came with Virtual DJ V6.1.2. I am looking for different effects that I can add to the list. Does anyone know where/how I can get more? I'd really appreciate the help
Posted Fri 25 Feb 11 @ 1:21 pm
first i would recommend you to register the version of VDJ that came with the controller.
Posted Fri 25 Feb 11 @ 1:57 pm
Do you know where i can register it? For some reason I am having trouble with it.
Posted Tue 01 Mar 11 @ 3:25 pm
It seems that you have registered the controller, as it appears in your sign in box. I think you have to upgrade to the pro version to get more effects. You will get a discount for the upgrade. Take a look here.
Posted Tue 01 Mar 11 @ 4:41 pm
