Hi yeah I just have a question I recently bought the Hercules MK4 and it came with virtual dj I connected my numark Ndx 200 s to it can I record the music playing on the cdjs using the MK4 as the mixer on virtual dj as a part of my mix
Posted Wed 23 Feb 11 @ 9:09 pm
Well, I'm sure you can, because your controller has an internal sound card which allows you to record your sets right from your controller. Can you set your CDJ's to MIDI, if so, then you should have no problem recording your sets.
I have the behringer BCD2000 and I connect my Radius 3000 to the BCD, and the BCD is plugged into my pc, and that's how I record my sets.
Posted Thu 24 Feb 11 @ 12:56 am
