Hey gs
Had my cdj's working fine but suddenly and I don't know why... Both decks are working as either 1 or 2 when i press the eject button both deck change at the same time but both are the same deck.. sound cards are 1 and 2 and this doesn't change when i press eject. it is usable but if you forget to switch the cdj over all the music cuts out because you press cue on the deck that is playing.. Very annoying!!!
Also since upgrading to the new version of vdj the software deletes my firewire hard drive then i have to reboot and wait for mac to check the drive for errors before it adds it back to the desktop.. then start vdj and the same thing happens again and it removes the drive. If i then plug my drive into the USB port it is all fine but then i have a lack of USB ports to plug everything in.
Anybody else had these problems??
One more thing when i type on the keyboard to search for music the music cuts out... If i type slowly its fine.. Never had these problems with older version on vdj??
If you guys can help as I'm out working tonight and every night till Sunday and its doing my pickle in now!!!
Thanks
Thanks
Posted Wed 23 Feb 11 @ 9:49 am
go to mappers deck assign and pick a deck 1 and 2
in the serato forum They complained about this mouse issue They said that it because it was linked to one of the usb port's and Using the same power source
Posted Fri 25 Feb 11 @ 6:24 pm
