I am working on some new intros for my next mixtape & I want to get some stuff from some movies. How do I rip sound from them? Usually I do a search on the net for stuff but what I am working on now is more specific.
Anyone?
Anyone?
Posted Tue 22 Feb 11 @ 11:44 am
well for one thing you can just record the sound with certain programs i believ you can do so with audacity.... just go on configu... and select the pc as your input so w.e plays in your pc will be recorded.... then you can edit it back in audacity or w.e program you like
Posted Tue 22 Feb 11 @ 12:19 pm
Hi.
There are many programs that can rip the audio from a DVD Nero wave editor, Im Too DVD Audio Ripper etc I have enclosed a link that could hekp you further http://www.dvd-guides.com/content/view/136/59/
good luck
good luck
Posted Tue 22 Feb 11 @ 12:23 pm
thanx, I'll give these a shot.
Posted Tue 22 Feb 11 @ 2:43 pm
format factory makes things pretty simple as well, and it's free
Posted Wed 23 Feb 11 @ 12:59 am
"If you want to rip from a DVD, use Rip DVD Plus. It is super easy to use and works well.
http://www.deskshare.com/dvd-ripping-software.aspx
If you want to extract the audio from existing media file on your PC, use Digital Media Converter Pro - http://www.deskshare.com/audio-video-converter.aspx"
Posted Wed 23 Feb 11 @ 11:07 am
Thanks everybody, I'll be messing around with it this weekend when I have some time.
Posted Wed 23 Feb 11 @ 11:47 am
For ripping sound from DVD movie on your computer, you might need an audio recorder, with which users can capture audio from DVD directly. I personally use this way to capture sound from DVD, just have a try.
http://www.recordstreamingaudio.org/capture-audio-from-dvd.html
Posted Fri 23 Sep 11 @ 3:24 am
