I Just Purchased The Mixtrack Pro and Im Running It With VDJ 7 an Im having a problem with it freezing after maybe 20 min of me using the device, esp when i am doing my scratching routine. It freezes with the other deck stiill playing the music but everything is unresponsive....does anyone know why this happens or have a solution? Thanx Alot!
Posted Tue 22 Feb 11 @ 1:18 am
Please ensure that you have the latest drivers and firmware installed from: http://www.numark.com/mixtrack
Are you using Windows Vista?
If so, MIDI support in Vista has a bug which will cause the driver of a MIDI device to crash and stop responding if too many MIDI messages are transmitted in one go (E.g: Excessive scratching or spinning of the jogwheels.)
The best solution is to upgrade to Windows 7 which does not have this problem. Windows 7 will also give you considerably improved system performance over Vista, which is a very 'bloated' and resource-hungry Operating System.
Posted Tue 22 Feb 11 @ 6:29 am
I had the same problem- Ive got a Mac
Posted Wed 24 Aug 11 @ 1:47 am
