Alright, my settings in virtual dj are:
no input
output to external mixer
the driver is numark as it does NOT give me the asio option
I have the newest version of the software.
My problem started after using it for a good 20 minutes. speakers hooked up through the xlr outputs, headphones, mic, everything worked.
Then the software started acting up, my controllers switched sides on the virtual dj. The screens on the mixdeck would have oposite tracks from the software, and the controllers were just flipped back and forth. Some of the fades wouldnt work, sometimes one controller would go out completly.
I've reinstalled the software several times, no idea what the problem is.
Any help is appreciated
thanks
no input
thanks
Posted Sun 20 Feb 11 @ 4:32 pm
Hit the eject buttons after you start VDJ up it should swipe sides.
Lemme know
Huey
Lemme know
Huey
Posted Sun 20 Feb 11 @ 5:04 pm
worked, awesome. one last question, wheres the headphone volume?!!?
Posted Sun 20 Feb 11 @ 7:35 pm
Look by that slider it'll say "CUE GAIN" and that slider is for which deck you wanna cue up.
Have fun
Huey
Have fun
Huey
Posted Sun 20 Feb 11 @ 7:41 pm
