Please can someone help and tell me why is it when I press the effects button on deck 2 ie the backspin or beatbreak it makes deck 1 stop as well but when I use deck 1 effects it doesnt have any effect on deck 2.
Basically using deck 2's backspin or beat break is causing me a problem on deck 1. I just cant figure it out ?
Posted Fri 18 Feb 11 @ 12:55 pm
what hardware are you using.go into your mappings and make sure the effects are not mapped to stop also
Posted Fri 18 Feb 11 @ 1:54 pm
