look,i have bought a new pioneer headset for listening to the other song..
the first time it worked,but the second time it always saids asio sound card not right(or something like that)
my boxs are in output 1 and my headphone at the top of the 4-mx,next to volume
please help me
please help me
Posted Tue 15 Feb 11 @ 1:04 pm
Posted Tue 15 Feb 11 @ 2:11 pm
i did it but it won't work,i don't have anymore the advanced virtual dj..
does that is bad?(bad englisch)
Posted Tue 15 Feb 11 @ 3:15 pm
Actually try this:
- Input : Line-ins
- Output(s): Headphone > Master Chan1/2 / Headphone Chan3/4
-Soundcard: DJ Console 4-MX
The LE version of VDJ needs to work in ASIO to have the headphone working, so it is necessary to select Line Ins for Input.
- Input : Line-ins
Posted Tue 15 Feb 11 @ 3:33 pm
if i do that it's just the same,
there come asio driver not acceptabel(or something like that)
Posted Wed 16 Feb 11 @ 6:22 am
acctualy,if i do that,it works,but if i press cue select to right deck,than you can hear the other song too on the box,i want i on my headphone
Posted Wed 16 Feb 11 @ 6:27 am
Check the position of the Monitor knob (next to the headphone volume).
If you want to listen to specific deck, put it to CUE. If you want to listen to the mix, obviously use the Mix position.
Posted Wed 16 Feb 11 @ 8:02 am
but if i do that,it makes any sence..
if u turn it to cue,i hear nothing,if i turn it to mix,the other song plays on the boxs
Posted Wed 16 Feb 11 @ 10:25 am
try this sound set up, input-none , output- headphones, soundcard 4.1 hercules 4mx and that should do it.
Posted Fri 04 Mar 11 @ 4:07 pm
I was having the same problem, and actually the setup above this post is the actual setting that works
Posted Fri 04 Mar 11 @ 7:16 pm
