I recently bought the Behringer BCD3000 console , and i managed to set it up , except the headphones , who are giving me a hard time .
I am using the VDJ Pro , the BCD3000 , on a Intel Dual Core 2 Duo , runing on Windows 7 . Any ideas ? I would really appreciate any kind of help .
Posted Sun 13 Feb 11 @ 11:41 pm
Did you start by verifying the audio configuration in VDJ ?
You should normally have something like this:
- Input : None
- Output(s): Headphone > Master Chan1/2 / headphone Chan3/4
-Soundcard: BCD300 (or however it is being detected by VDJ)
- Input : None
Posted Mon 14 Feb 11 @ 11:29 am
- Input : None
This is a screenshot of my soundcard options , the console is plugged into the pc only with an usb port cable
http://imageshack.us/photo/my-images/576/vdjv.jpg/ maybe there is something wrong with my headphones input in the bcd3000 , because i never hear a clean , normal sound in them (when they are plugged into the bcd ) , i just want the speakers to work at the same time with the headphones , the problem is that out of all the settings , the only one who makes the speakers work at full capacity are the following :
- Input : None
- Outputs : Single output
- Soundcard : Simple > primary sound driver
- Input : None
- Input : None
Posted Fri 18 Feb 11 @ 10:08 am
