Hi All,
I am looking for some Ultra Cheap DJ Equipment to work with my Hercules MK4. I find that The Jogwheels are too Small, and so I would Like a MIDI Turntable. I am also looking for all sorts of other equipment but as long as it is ULTRA CHEAP. I am still Trying to pay for Virtual DJ Pro. ( http://djsheriff.chipin.com/). If anyone knows where I can get any or if anyone wants to sell me their old equipment, I would be happy(as long as the store is in canada).
Thanks a lot,
DJ SHERIFF
REMEMBER IT HAS TO BE DIRT CHEAP!!!
Thanks a lot,
DJ SHERIFF
Posted Fri 11 Feb 11 @ 10:37 pm
A word of advice, if you are serious about doing this, don't cheap out.
Posted Sat 12 Feb 11 @ 8:47 am
DJ Ace Cap1, I know but i cant really afford expensive equipment, I am still a student. I am just looking for people who have lots of things they don't use anymore and want to get rid of.
Posted Sat 12 Feb 11 @ 9:05 am
Thats a good piece of advice, don't go cheap as it will COST you MORE in the long run, student or not. Prioritize what you NEED and start there. I don't think to many of us acquired ALL of our "toys" in one day... crawl before you walk...
Posted Sat 12 Feb 11 @ 11:19 am
DME-CEO, DJ Ace Cap1, Okay, thx for the advice, i will do that.
thx
thx
Posted Sat 12 Feb 11 @ 12:02 pm
Hi mate
You can find some good deals on decent second hand equipment in your local free adds paper and also by searching on line. Keep an eye out on Ebay and similar auction sites. If you have a salesroom/auction near you you can sometimes find gear like amps and speakers that will go for peanuts. You may have to be prepaired to make some repairs, like changing out a blown speaker driver or replacing a damaged jack socket but its all a good learning exercise.
best of luck
Daz
best of luck
Daz
Posted Sun 13 Feb 11 @ 9:08 am
