I cant seem to get my samples to match the tempo of the song. The default samples work fine but when i load my own mp3 samples the sampler does not follow the tempo of the song even if beatlock & pitch are on.
How does BPM get the tempo of the sample?
Is there a way to pitch bend the sample?
Posted Thu 10 Feb 11 @ 4:29 am
I had this problem too once. The only way around it was to go back and rerecord all my samples to .vdj format, sucked!! But it worked.
Huey
Huey
Posted Thu 10 Feb 11 @ 7:24 am
Wow not sure why the format would make a difference?
Posted Thu 10 Feb 11 @ 10:28 am
Huey...how do you record in .VDJ format?
Posted Thu 10 Feb 11 @ 11:42 am
You use a skin with the sample recording station on it. Then you just set the loop and hit record. It should now show up in slot 1. Just name it and save. For jingles I don't even bother with it. I use drum loops and such. Also make sure your cbg is right on!! Very important!!
Hope that helps
Huey
Hope that helps
Huey
Posted Thu 10 Feb 11 @ 12:34 pm
