Topic: Virtual DJ LE + PRO
Hey guys! - I'm new in the DJ community, and I just bought a Numark Mixtrack PRO, and it is absolutely awesome!
Virtual DJ LE came with the package, and I figured the discount out for the PRO version.
But I'm wondering about one thing, it says I can upgrade to the PRO version, for 20 days. When i have it upgraded for those 20 days, I'm wondering if I can download the effects and skins from this site? Or do I need to buy the PRO version before I am able to use and download those.
Best regards, Jesper :-)
Posted Wed 09 Feb 11 @ 3:04 am
Hello,
as you said - you need a Pro Status in the forum before you can download. The status you will get by entering the Pro Full serial in your profile: https://virtualdj.com/users/edit.html
Greets, Heiko
Thanks for the answer :-)
