Hi,
I just bought a new computer and re-installed VDJ.
It's windows 7 (64-bit) with core i5.
Whenever I run VDJ, it seems like wave of music shown on the screen is passing 10 times faster than before! No idea why its like that.
Does anyone have answer to this? If so, please help me!
Posted Tue 08 Feb 11 @ 12:14 am
Are you using the default VDJ screen?
There should be numbers on the side of the waveform (1, 2 and 3)... If you click on one of those it will zoom in/out on the waveform thus slowing the graphic down... and I think you can do it with the scroll wheel on a mouse but not sure I haven't got my VDJ to hand.
Si
Si
Posted Tue 08 Feb 11 @ 6:12 am
Use the default skin. You will find a slider on the left side of the wave form. You can adjust the zoom of the wave form to fit to your needs.
Posted Tue 08 Feb 11 @ 6:38 am
Si
thank you so much!!! it worked!!
Si
Posted Tue 08 Feb 11 @ 3:50 pm
thank you so much!!!!!!!! it worked!!!! thank you.
