Hey,
Ive been using the RMX for about 3 months now and want to upgrade to tables. I tried the ns7 before and love their table setup. Guitar Center has a sick deal on the V7s right now, and I want to get a couple but I don't know if I need to upgrade my mixer.
The main concern is that the V7 has 2 output channels, each controlling a separate deck on the single v7. (flick the witch in the back and it switches functions to the second deck). so technically I don't need a second v7 to dj and have all the functions of a standard 2 deck setup.
If I buy 2 of them I would have 4 output channels and 4 decks to mix with. The RMX only has 2 channel input, so I can add the 2 v7s but I am not sure if I will be able to control the other decks within each v7.
Also if I was to add a MIDI keyboard to my setup would I need another channel open? or would I only need another one open if I choose to have the MIDI keyboard produce audio in its own separate channel?
Pretty much I wanna know if I should upgrade my mixer, and if so, any recommendations?
Thanks in advance.
Thanks in advance.
Posted Sun 06 Feb 11 @ 10:35 pm
No one tried this setup before, or is a fan of the v7s?
There going for 400 bucks each, i must say, that's really cheap for motorized tables.
Posted Tue 08 Feb 11 @ 9:56 am
I have a NS7 but one of my partners has V7's.
The V7's are real good. I don't know how good they will work with VDJ. I can tell you that you would want two V7's rather than one. I tried spinning on just one and it can be done but it's a ROYAL pain in the ass.
I once owned the RMX but it was not for me. I can't see using V7's with a RMX. If it were me, I would upgrade the mixer as well.
I'm sure someone else will be able to answer your other questions.
Good luck.
Good luck.
Posted Tue 08 Feb 11 @ 10:22 am
It might be worth considering upgrading your mixer anyway (it means you can use your current one as a backup too).
There is a store over here selling 2 V7 units with a free X5 mixer for around £995 (GBP) so you might want to have a look around on your side of the pond to see what the best deals are there.
A lot of people with V7's have the X5 so it cant be a bad little mixer... What I'm looking at / waiting for though (looking to purchase V7's later this year) is the Numark X7, it enables you to have 2 V7's and the mixer (+midi) plugged into your PC via 1 USB port, in addition the mixer has 2 USB ports so you can have 2 DJ's plug in for swap overs or whatever you could find a need for it.
Just a few ideas but it's your choice at the end of the day, if you can get 2 V7's and a free mixer... Why the hell not?
Si
Si
Posted Tue 08 Feb 11 @ 10:25 am
I'm rockin exactly what yur thinking. :) 2 V'7s & a RMX. I have the V7's linked together (2 deck setup), scratchin & mixing is good. I say go fo it. I rock video all night at the club.
Posted Tue 08 Feb 11 @ 11:49 pm
I don't see why it wouldn't work. It would actually be a good idea to use the RMX because of its compatibility with VDJ, which is exactly why I'm considering using mine with 2 V7s.
Posted Tue 08 Mar 11 @ 9:29 am
Hello, did you ever figure out how to connect a midi keyboard to virtual dj? im trying to do that right now and i cant find a good explanation.
Posted Thu 12 May 11 @ 10:59 pm
