im looking to upgrade my midi controller, have an ion icue at the moment, its ok, but want something with a bit more to it.
been looking at the Numark Omni and M-Audio Torq Xponent, also Hercules RMX, just cant make my mind up.
anyone any suggestions? something around the £300-£400 mark
cheers
cheers
Posted Thu 03 Feb 11 @ 4:10 pm
hmmmm...nevermind, i bought one regardless
Posted Mon 07 Feb 11 @ 2:38 pm
sorry babes... if i'd have seen your request for help, i'd have responded... DOH!
what did you get in the end?
Seana
XXX
Seana
XXX
Posted Mon 07 Feb 11 @ 6:26 pm
seeing as you called me babes...everything's cool lol!!
ended up splashing out a bit more and went for the pioneer SEP-C1
http://www.decks.co.uk/products/pioneer/sepc1
though i've literally just noticed in the last few minutes that it doesnt have a crossfader:(
any ideas on how well this would work with VDJ6? it comes bundled with DJS, but i had a quick look at that, and it's just not even on the same planet as VDJ
Posted Tue 08 Feb 11 @ 2:51 pm
Taco...your going to need a mixer and soundcard to go with the Pioneer, as it's just a controller.
I'd have suggested the RMX in the price range you originally suggested - full MIDI controller with built in sound card and full mixer control and it's plug and play with VDJ.
Simon
Simon
Posted Wed 09 Feb 11 @ 3:52 am
thanks simon. didnt realise that at the time:(
can you recommend a good mixer that is compatable with this controller....something not too pricey as ive went way over my budget already:S
cheers
cheers
Posted Mon 14 Feb 11 @ 7:57 am
If you wish to be able to video crossfade, you will need a MIDI capable mixer such as Pioneer DJM-5000
Alternatively, you could map a knob that you do not need to use on the SEP-C1 to video_crossfader or a button to video_transition to performan an automatic transition to the appropriate deck. For basic mapping instructions, please see https://virtualdj.com/homepage/jpboggis/blogs/4149/VDJscript_Mapping.html
NOTE: To use MIDI controllers including the Sep-C1, you will need to upgrade to the full VirtualDJ Professional: https://virtualdj.com/buy/
The version that you have now is a limited edition (LE) of Numark Cue and will only work with the Numark Total Control.
Posted Mon 14 Feb 11 @ 12:26 pm
thanks
had a look at the DJM5000....bit too much for me right now, my son would have to go without nappies for the next few months lol!!
opted instead for a DJM350
Posted Mon 14 Feb 11 @ 6:10 pm
