Posted Wed 02 Feb 11 @ 5:37 pm
I never heard the Technical pro but i know its a very low budget brand. I would get this instead. Its around the same price and i know thsese good for the price. http://www.guitarcenter.com/Behringer-EUROLIVE-B215D-Active-PA-Speaker-System-105640619-i1449708.gc
Posted Wed 02 Feb 11 @ 9:22 pm
what about Mackie Thump TH-15A Powered Speaker over the behringers
Posted Wed 02 Feb 11 @ 9:27 pm
The Mackie Thumps sound good but they are not loud. The low end is just 150 watts rms & 50 watts highs. They sound good for a small party
Posted Wed 02 Feb 11 @ 10:05 pm
I do have the k12 s and sub and mackie 450's.. looking for something that will last for smaller rooms
Posted Wed 02 Feb 11 @ 10:22 pm
The Mackie Thumps or the Behringers would be fine. The behringers are alittle louder.
Posted Wed 02 Feb 11 @ 10:49 pm
Best thing I can tell ya,
DON'T GET TECHNICAL PRO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
The Thump's are good and the Behringers are good too. Behringer is a bit louder but requires good eq from your mixer.
Posted Fri 04 Feb 11 @ 5:03 pm
