Topic: vestax mixer controller
thnkin bout purchasing a vestax mixer , would it go good with virtual dj???
its a VESTAX VCI-300 MKII Serato ITCH DJ Midi Controller
Posted Wed 02 Feb 11 @ 3:01 am
The Vestax VCI-300 is natively supported (Plug and play) by the latest VirtualDJ Pro, which you can download from the Download Center if you have not already done so: https://virtualdj.com/download/updates.html
However, because this controller is designed for use with Itch, it does not have its own standard ASIO drivers available to allow you to use the built-in sound card with VirtualDJ. If you wish to use its internal sound card, you will need to use ASIO4ALL - Please see https://virtualdj.com/homepage/cioce/blogs/3832/_ENG__Vestax_VCI-300_Typhoon_Spin_audio_setup_on_Virtual_DJ_6.html
thanks heaps man !!! much apreciated!!!!
