Was Up!
im here becuase i bought a Deejay trim with timecode. my problem is that always in one channel when i connect everything i get a Hissing/high pitch noise i dont know were its coming from if anyone can help me out Thanks
Equipment
Dell Inspiron Laptop with 4 Ram 500 Gig Hardrive Runing on Windows Seven.
Two Stanton t.80 Turntables and a stanton smx.202 mixer and the Hercules Dj Trim 4&6
Note: I Run The Music From an External harddrive
Equipment
Posted Tue 01 Feb 11 @ 12:33 am
In the TRIM Control Panel, in the ADVANCED tab, make sure the Hardware Mixing is set to USB Streaming 1/2 (Default), otherwise the audio signal from your turntable will be sent automatically to the main Output 1/2.
Posted Tue 01 Feb 11 @ 7:38 am
Thanks Tried it and now the high pitch noise is out but i still get a Rumbling Noise Between Miixes any Solutions?
Posted Fri 04 Feb 11 @ 2:13 pm
