Hi guys i'm having a problem with the cdj 350s when i connect to vdj i have it set to aiso but when im playing a track the audio cuts out and then i have to tap play again on the players for it to start back. i have even tried setting the cdjs as sound card but same issue, can you please help me, Thank you
I have tried both 6.1.2 and vdj 7
Posted Sat 22 Jan 11 @ 6:51 pm
same here! when you r loading a track to cd2 then there is no sound on cd1.till now i m using 350's knob to load the song. i m wondering if the same trouble will happen if i will load the song using pc's mouse.
Posted Wed 26 Jan 11 @ 4:28 am
Thanks for the reply i thought i was the only one with this issue. Can someone please assit us, I have contacted pioneer and they said its definitely not the players. Is there anyone out there to help please, thank you
Posted Mon 31 Jan 11 @ 8:50 am
I have had a similar experience where there is loss of sound until u move the pitch slider and then sound comes back-but i noted this mainly happens when u load an mp3 with either high/low frequency.(im using cjd350)i have even thought of re-mapping the pitch slider to another function to eliminate the problem
Posted Sun 06 Feb 11 @ 4:00 pm
Hey there are you still having the problem...im still having the issue but i played around with the latency settings on the pioneer cdj utility but it cuts off rarely now but when u scratch it does not sound good at all and it lags...
Posted Wed 16 Feb 11 @ 12:10 am
Same Problem here can anyone help please?
Posted Thu 13 Oct 11 @ 5:11 am
same here.please help!
Posted Sat 11 Aug 12 @ 9:58 pm
Same problem here with CDJ850
Posted Sun 12 Aug 12 @ 1:08 pm
