I have noticed strange bass overtones in songs that I speed up or slow down when keeping the pitch locked. Does changing the tempo create strange sounding overtones in the bass?
Posted Fri 21 Jan 11 @ 6:28 pm
Has anyone noticed a gurgle sound in the bass when they change the tempo of a song?
Posted Sat 22 Jan 11 @ 10:08 am
If you are using master tempo/keylock, check that your master tempo is set to Advanced Stretching in CONFIG -> Performances
Posted Sat 22 Jan 11 @ 1:34 pm
Yes that does help, although there is still a rumple in the bass.
Posted Sun 23 Jan 11 @ 1:54 am
All I noticed was a 'metallic' sound once you change the tempo. Not hateful as it goes away w/ the next track or turning off MT and back on again.
Posted Sun 23 Jan 11 @ 2:40 pm
This happens with Cd players also.
Posted Sun 23 Jan 11 @ 7:20 pm
