Have just signed up to Listen2myradio.com which gives the data needed when broadcasting using virtualDJ. Has been brilliant being able to play out to friends. Want I really want to do and seem to be having problems with is having a line in source which is running from the REC output on a Gemini mixing desk into computers sound card and for this audio to be heard when broadcasting. I have changed input settings in the config tab which has Master Master/mic and line in but nothing seems to work. The only thing I can think off is I need a new skin layout which gives volume controls when using external sources, or maybe a newer version of VDJ as I am currently using DJMixStation3. Any help would be much appreciated.
Posted Tue 18 Jan 11 @ 2:47 pm
the sound card or chip will make all the difference-- you will need to open the option in control panel/ sounds and check the line in config--if you are trying to bring it into virtual I am not sure, but i use a mackie cfx12 mx 2 with my rig and run on shoutcast and run virrtual into the mackie.
doing it that way you get the whole stereo mix- i cant say much for the line in on virtual 7 as i have not found the way to config that myself yet-- and actually get it to work
Posted Tue 18 Jan 11 @ 4:53 pm
