Does anyone have suggestions on what's going on with this. I cannot get my VMS4 to work correctly with VDJ 7. When i select the headphone out, deck two sound comes through on both decks.
When I use the 3 channel external mixer setting, everything works great except the sample settings don't work like the siren and others
I launched the the VDJ LE that came with the VMS4 and everything works fine. I never registered the LE version because I have the pro version before buying the VMS4.
I'm running latest version of Firmware on the VMS4. So this makes me wonder if this is an issue with VDJ 7 since it works with the LE version.
Ideas?
Posted Sat 15 Jan 11 @ 8:49 pm
Posted Sun 16 Jan 11 @ 3:25 am
I spent the last two weeks trouble shooting trying to figure it out myself before I posted anything...as soon as I posted this I figured it out. I reloaded the ASIO 1.07 driver and it took care of the problem I was having. Sound is coming out of the respective channels now, samples work too.
Thnaks for the links, they are good to have anyway.
Posted Mon 17 Jan 11 @ 9:59 am
that's ok mate :^)
Posted Mon 17 Jan 11 @ 10:50 am
Can anyone help me?
Everything is working fine, but when i record my mix it, you can hear both decks at the same time. rather than what im mixing:(
Posted Wed 20 Apr 11 @ 9:35 pm
You can't do everything pro users can do. Look here for comparisons and limitations. Also, start your own thread, because this topic has been answered.
Posted Wed 20 Apr 11 @ 9:45 pm
Please dont double post.
An answer is available for you here .. https://virtualdj.com/forums/146550/General_Discussion/VMS4_Recording_Issues__someone_help.html
Posted Wed 20 Apr 11 @ 10:55 pm
