I've been using the RMX for a few days now, i turned it on the other morning and for some reason the main volume slider doesn't affect volume? It goes up and down on virtual DJ but doesn't affect the volume. Does anybody know why
Posted Thu 13 Jan 11 @ 5:03 am
What are you listening to the music through?
Laptop Speakers, Headphones plugged into the Herc, Other speakers plugged into the outputs on the back of the Herc?
If it's speakers plugged in, try plugging them into the other output:
As default it's set up to output the Master audio to channels 1 & 2, and the headphones to 3 & 4; so if you have the speakers plugged into 3 & 4 your actually listening to the headphone channel.
But without knowing your setup I cannot say exactly what your problem is.
Si
Si
Posted Thu 13 Jan 11 @ 6:55 am
I've got headphones plugged into 1+2 RCA inputs on the rmx, BUT there was no problem with the main volume until now? It just randomly hapened, it worked with headphones before.
Posted Thu 13 Jan 11 @ 10:20 am
You won't get to hear anything plugging your headphones into an input when you should be using an output source.
I mentioned it before in another post of yours, you need to get to a dj or audio shop to have a practical demonstration on how to set up equipment, do you not have a friend or family member that can help you, or the shop you purchased the RMX from.
Hope this helps you, but if you can't follow this then you really need to follow my previous advice...
Rember you need to have an amplifier to connect your rmx to if you want loud music,
instead of connecting to mixer connect from RMX to Amplifier then to speakers.
your headphones go into the headphone socket located at the top right corner on the RMX
Read your RMX manual, believe it or not, it will help you.
Posted Thu 13 Jan 11 @ 10:51 am
Ah i give up this dj business, too much hassle. I went maplins but there useless.
Posted Fri 14 Jan 11 @ 1:43 pm
