hi guys, so ive dug out the decks and TC's and finally got the sound sorted. not sure how many of you remember all the chew i had trying to get them set up a while back but i discovered today theres an auto button in the esi control panel and when you click it, it allows the sample rate to be automatically chosen. not before i assumed it was on auto as the button was lit up.
trust esi to use backwards buttons. i clicked it in frustration while i was randomly clicking and stumbled across it. so anyway, no more distortion and crackeling.
the problems i have now, is i have huge amounts of bass pumping through my system. vdj is set to mid way on the bass, on my mixer i cant go past 1/4 way without bass totally drowning out the mid and high ranges. the bass is turned down as low as possible on my amp too. any ideas??
2: i have a constant hum from the speakers eventhough none of the gain/volumes are past half way.
3: one of my TT's is lagging timewise because the belts bolloxed and i cant use my DD TT's because i need some silly little phono - phono connection blocks that i searched all over town for today and cant find any.
other than that things seem to be not too bad.
cant wait till march, should have a bit of cash saved up by then. i want some 1210's or some stanton str8-150's.
@Dazmax
WOOOOHOOOOOO! FINALLY!
@Dazmax
Posted Wed 12 Jan 11 @ 5:39 pm
