Hi I'm new to the forum.
I have Virtual DJ 7 Pro for Mac and I'm using the Numark iDJ3. I'm not sure how to set up the headphones so that I can cue in the next song. I've tried a few of the settings but I can't get it right. When I turn up the cue volume on the mixer, it outputs the sound which is wrong.
Thanks in advance.
Thanks in advance.
Posted Sun 09 Jan 11 @ 11:08 pm
Sound outputs: headphones
sound card: if your on mac choose 4out card, windows, use ASIO and check ultra low latency
make sure output 1/2 is master and 3/4 headphones
and also
REGISTER YOUR SOFTWARE.
and also
Posted Mon 10 Jan 11 @ 12:04 am
I am also having difficulties getting the headphones to monitor. I am using Windows 7. I can only hear the music throughthe headphones if I have the cue source set to MASTER.
Posted Fri 04 Feb 11 @ 6:18 pm
I have the same problem I cannot hear cue source A/B through my headphones so I can't listen to the next song before I play it.Please can you confirm what my sound settings should be ?
Posted Sun 15 May 11 @ 6:59 am
I also have the same problem I can only listen with the headphones if i have it in master but when i put in A/B i doesnt listn something
Posted Wed 19 Oct 11 @ 4:10 pm
hey im new to this site but djing for a while now
anyway i have gone through the great advice to get headphones working on the idj3 controller with vdj and it keeps coming up with an error message about the asio soundcard i need help please
thank you
thank you
Posted Thu 03 Nov 11 @ 3:15 pm
Hi,
I have the Numark IDJ3 and its great but when I try to hear the other song when i play, i only can hear the one that is coming out the master speakers, I switch the switch to A/B and my headphones like stop working, I only can hear the song that the slider is on, can anyone help.
Thanks.
Thanks.
Posted Sat 07 Apr 12 @ 3:41 pm
I was having the same problem, no sound when set Cue A/B. When i configured the Sound Card as "Numark" i started hearing on the headphones. I still have one problem, can't hear both songs at the same time. Can anyone help?
I'm using IDJ3 with Virtual DJ 7 Pro.
Posted Sat 05 May 12 @ 4:34 pm
You need to have the PRO version in order to "Pre Listen" im currently struggling with the settings on getting my cue's to go through my headphones on the soundcard of the iDJ3. Anyone have it set up yet?
Posted Sun 08 Jul 12 @ 10:51 am
Definitely, you dont have to use Pro Full version to prelisten with iDj3. The LE version that comes with the device is capable to provide proper pre-listening.
The iDJ3 has no native sound drivers so your OS takes care of that.
https://virtualdj.com/wiki/iDJ3.html
Notice, in the above link, that your OS should detect 2 sound cards, one for master and one for headphones. But i have seen OS detecting the iDJ3 sound card as 4ch sound card and not as 2 stereo. In this case, you might need to change the sound setup as ..
Inputs..None
Outputs..Headphones (chan1,2 Master / chan 3,4 Headphones)
Sound card ..(4.1 or 4out for Macs) and next to that choose Numark.
You also need to make sure your Sound card is set to Quadrophonic mode to ensure sound comes through headphones (ch 3,4) as well.
For Macs.. Goto Applications-->Utlities->Audio Midi Setup, select the Numark sound card, Configure speakers...set to Quadrophonic.
For PCs...rightclick on the speaker icon on your taskbar, choose Playback Devices, then select the Numark sound card and choose Configure-->Set to Quadrophonic.
About not being able to prelisten both decks at the same time, yes that is not available in LE version, as the PFL buttons are mapped as Select. You can map then as pfl, but this is only possible with the Pro Full version.
Inputs..None
Posted Sun 08 Jul 12 @ 7:38 pm
Posted Mon 30 Jul 12 @ 10:34 pm
The "Configure Speakers" button on my Numark MIDI config is greyed out (using a 2012 Macbook Pro OSX 10.7.5)
Any suggestions for how to adjust this to enable the A/B cue source?
thanks
thanks
Posted Tue 11 Dec 12 @ 4:38 pm
Hi
On Mac should be set:
MULTICHANNEL and QUADRAPHONIC speaker MODE.
This on FINDER----APPS---UTILITIES--- AUDIO/MIDI SETUP
You should be seen AUDIO SETUP.
After doing this, open your virtualDJ software and set the sound settings inside VirtualDJ as:
INputs - none
Outputs -HEadphones
Sound Card - 4 Channel - Numark USB Audio
INputs - none
Outputs -HEadphones
Posted Tue 11 Dec 12 @ 6:49 pm
DJDAD SICK
Posted Thu 19 Sep 13 @ 11:01 am
thank you dj dad it help me out
Posted Sat 14 Jun 14 @ 9:24 am
