I have a Macbook Pro and and I am trying to use it with an Alesis io-2 sound card...My configurations are as follow:
Input: None
Output: Headphone (Master: Chan 1&2 / Headphone: Chan 3&4
Sound-card: 4-output card: io-2
The problem I am having is that can't preview the songs indiviually. The same sound I get from my speakers I get it on my headphones..In addition, I only get sound from the right headphone.
Any help is greatly appreciate it,
Thanks
J-Rod
Input: None
Thanks
J-Rod
Posted Sat 08 Jan 11 @ 11:43 am
Anybody Please!!..Can someone from technical support respond please.
Thanks
Thanks
Posted Sun 16 Jan 11 @ 8:11 pm
Maybe one of your soundcard knobs let you control the headphone mix.
Sounds like the knob "Monitor Mix" is the one you need.
But you can also use the MIX/CUE function on the skin.
Posted Mon 17 Jan 11 @ 4:23 am
