Topic: Saving bpm info?
I am now calculating the bpm's of all tracks in my library, is there a special file somewhere in the software which I can save so if in the future my machine should break then I won't have to scan all files again?
Posted Fri 07 Jan 11 @ 3:21 pm
i too would like this info as when i decide to scan my info its going to take 472 hours. so by no means do i want to loose it once ive got it.
All you have to do is, open VDJ then highlight your track or "control A" to highlight them all, next right click and a window with options will appear. Click on "file info" I believe. Another window should open up it from here you can write back all that info, bpm, key, comments etc. etc. to the ID3 tag of the song.
If you have a lot of tracks this could be a slow and painful process but well worth it!!! I have purposed that this is automatically done when you are analyzing tracks which would take the sting out of having to do it manually. If you agree look here, https://virtualdj.com/forums/139562/Wishes_and_new_features/Add__KEY__and__BPM___________.html , and show your support maybe together we can get this changed!!
Hope that helps
Huey
