Installed new v7.02.
When setting to 4 decks, no sound out of decks 3 or 4.
Decks 1 & 2 work.
Set to external mixer and have PCI Maya44 sound card.
Says ASIO not configured, but it works with older version of VDJ
Without ASIO setting and just setting it to normal outputs on card - no sound
Hope this makes sense
Cheers
Decks 1 & 2 work.
Cheers
Posted Fri 07 Jan 11 @ 7:55 am
Install the ASIO driver and configure with Advanced Sound Config.
Hope this helps,
Cheers
Hope this helps,
Cheers
Posted Fri 07 Jan 11 @ 1:33 pm
