I seem to have this problem occur every now and then where I will go and select a track which highlights blue as normal but then when i select other tracks underneath, they also are highlighting. Putting it simpler, I can actually have the whole browser highlighted if i click on every track. Why is this happening please ? never known this problem before.
Posted Mon 03 Jan 11 @ 2:15 pm
Also when this happens, everthing else crashes and all my mappers wont work etc so have to close program and reload.
Posted Mon 03 Jan 11 @ 2:18 pm
Have you changed anything in the keyboard mapping?, try resetting it in config>mappers
Keith
Keith
Posted Mon 03 Jan 11 @ 2:45 pm
hello. No. This is nothing to do with the mapper. This is just something randon that happens now and then. Its definately the version because I have not changed anything except upgrades.
Posted Mon 03 Jan 11 @ 3:25 pm
sure its not a faulty ctrl key on the keyboard? it might be getting stuck. try cleaning the keyboard with the computer turned off.
just a thought.
just a thought.
Posted Mon 03 Jan 11 @ 4:19 pm
Purely random, not happening to anyone else as far as I am aware
Keith
Keith
Posted Mon 03 Jan 11 @ 4:33 pm
Ok thanks, I will do that first thing tomorow and report back after work. Its happened 3 times now so will let you know :)
Posted Mon 03 Jan 11 @ 4:35 pm
Cool, let us know how u get on!
Posted Mon 03 Jan 11 @ 5:07 pm
Posted Mon 03 Jan 11 @ 5:08 pm
