I dont know if i'm not doing something wrong, but it seams that every time I start up VDJ and load my library's the program is not recognizing my folders. I've have right clicked on my folders and added it to the search database and searched BPM's but I still get that yellow icon next to each track and or the clear icon with a red symbol. Can someone give me some insight on what i'm not doing right. I've even waited until I scanned all my files and created a sub folder and that doesn't seam to even help either.
thanks in advance
thanks in advance
Posted Sun 02 Jan 11 @ 6:25 pm
Any one with any help on this?
Thanks in advance.
Thanks in advance.
Posted Tue 04 Jan 11 @ 11:34 am
Not sure I understand you. You should not have to load your library everytime you start VDJ, it should be there. Are your drives internal or external?
Posted Tue 04 Jan 11 @ 2:13 pm
Both...I get my music in the program But everytime I start vdj program I get those yellow icons next to the tracks and when i start to play the track its blairing loud, and the bpm's are all gone. I even get the clear icons with a red symbol on top of the icon also. I've even tried scanning all music to data base and then clicking the blue icon to make a sub folder. So everything should be in the data base folders but that folder is gone once I start up again.
Thanks for your help.
Posted Tue 04 Jan 11 @ 3:55 pm
