i got a rmx and it came with 5.2 not LE how do i get LE so i can continue using my controller
Posted Sat 01 Jan 11 @ 12:19 pm
There should be a LE disc and serial supplied with the console from the manufacturer. You have registered software here, is there anything showing in your download center on this site?
keith
keith
Posted Sat 01 Jan 11 @ 12:22 pm
if you already have LE installed then just use that. but why would you want limited edition when you can have full version 5??
limited edition isnt an edition thats limited because theres only so many and its a good thing. its a limited edition because it has limited features. its the most basic form of vdj.
you are really much better off using version 5 if its the full edition. especially if you plan to add timecodes later on.
Posted Sat 01 Jan 11 @ 12:26 pm
If you would like more than what the free limited DJ Console Edition offers, then you can upgrade at a considerable discount to the latest VirtualDJ v7.0.2 Pro: https://virtualdj.com/buy/
There have been many changes and improvements to the software since v5, including support for 4 or more decks: https://virtualdj.com/wiki/VirtualDJ_History.html
Otherwise if you are happy with the LE that comes with your console, you can continue to use this. You can download it again at any time from the Download Center: https://virtualdj.com/download/updates.html
Please ensure that you have the latest DJ Console drivers and firmware installed. A link to download this can be found on the following page:
https://virtualdj.com/wiki/Common_Device_Drivers.html
Posted Sat 01 Jan 11 @ 12:38 pm
after the pro trial in v5 is over will i still be able to use my controller?
Posted Sat 01 Jan 11 @ 12:44 pm
Did you get an LE disc with the controller?
What appears when you go to the download center?
Which version do you currently have isnstalled?
Keith
Keith
Posted Sat 01 Jan 11 @ 12:50 pm
Yes, the free DJ Console Edition that comes with the Hercules DJ Console will only work with the DJ Console connected and supports use of the console.
It does not support any other hardware or use of the software stand-alone without the console connected.
The Pro trial will expire after 20 days.
We would also recommend trying Home FREE v7 so you can try the latest features of the software. Home FREE allows the DJ Console to be tried for 10 minutes at a time: https://virtualdj.com/download/free.html
Posted Sat 01 Jan 11 @ 12:55 pm
