I am reviewing the Midi Fighter for http://www.digitaldjtips.com/, and working on some mappings so I can use Virtual DJ in my review.
Here's my question:
If I map a button on the computer keyboard, the OS's auto repeat kicks in automatically. So for instance, on my laptop, if I map a button to
When I hold that button down on the keyboard, after a split second it continually repeats, meaning the master_volume increases without me having to repeatedly press the button.
However, if I program a key on the Midi Fighter to the same function:
using the Simple Midi Wrapper, pressing the button has the effect of increasing the master_volume parameter once only, as there is no auto repeat.
Is there a way of making a Midi Fighter button (or I guess any Midi button) auto repeat if it is held down, in the same way as it functions on a keyboard?
Thanks for any help! :)
Here's my question:
master_volume + 1
master_volume + 1
Posted Fri 31 Dec 10 @ 6:27 am
Via Midi or Hid is not possible to have an auto repeat, I will try to ask another time in the next future beta session because you are not the first one that ask this function.
Posted Fri 31 Dec 10 @ 6:32 am
That's great, thanks. It would allow for the ability to use two buttons to "copy" the function of a fader or knob - really useful in keyboard mapping and would be good for Midi too. Much appreciated.
Posted Fri 31 Dec 10 @ 6:33 am
You can set up customized repeats for button presses using "Autohotkey": http://www.autohotkey.com/. I guess your midi fighter device is MIDI/HID. If not you can use Bome's MIDI translator which turns MIDI into keystrokes.
Im just learning how to use Autohotkey myself, as I would like to set up repeat macros in VDJ. I'd like a button to repeat X number of times if I press it once, and sometimes spread out over a period of time - for example for controlling very gradual tempo changes.
Posted Fri 11 Feb 11 @ 8:32 pm
