Just updated the 3700s to the latest firmware (2020) in hopes of solving an issue I'm having with VDJ not responding with the vinyl properly. If I pull the record back and hold it, it'll often jump forward/backwards in VDJ. I read the new hybrid mode will likely fix this, but now the 3700s don't show up in the ASIO control panel. Do I need an external sound card if I'm using them in hybrid mode? If I do, I have a Versaport I could use, but when I plug it in, it seems like it would work, but the platters don't respond.
Kinda scratchin' my head here. I'm usually the local go-to guy for this stuff. lol
Posted Thu 30 Dec 10 @ 8:01 am
^bump...
Posted Thu 30 Dec 10 @ 10:59 pm
To use hybrid mode you will need an external 4-in/4-out ASIO sound card such as Hercules DJ Trim, Native Instruments Audio 4 DJ, ESI Maya44 USB, etc.
The sound card in the S3700 cannot be used in hybrid mode because it is being used to output the timecode audio signal (In the same way as a conventional non-MIDI capable CD player.)
Posted Fri 31 Dec 10 @ 4:29 am
Ok...is there instructions on how to set it up? I couldn't get the software to react to the platters when I tried it.
Posted Fri 31 Dec 10 @ 5:50 am
Please see the user manuals for VirtualDJ which you can find in the following locations:
PC: Start -> Programs -> VirtualDJ
Mac: /users/YOURNAME/Documents/VirtualDJ
On-line: https://virtualdj.com/wiki/PDFManuals.
Posted Fri 31 Dec 10 @ 5:01 pm
I looked there first but didn't see anything for setting up the DN-s3700s in hybrid mode.
I managed to figure it out through trial and error, but an addendum is needed, unless I flat out missed it. Denon's site says how to set the 3700 in hybrid mode for Serato, but nothing specific for VDJ. My issues were how to tell VDJ I'm using hybrid TC, but at the same time MIDI. After updating the mapper, I experimented with the different Scratch Live/3.0/2.0/1.2 options (or whatever they are) followed by what type of TC option to use under Config timecode. I got it working using Scratch Live and the very bottom TC option
Posted Sat 01 Jan 11 @ 1:04 pm
hi my name is carlos i just installed the 2020 firmware and using it in hybrid mode and im am using the virtualdj 7.02 with its own box
everything works but when i press play the music doesnt move i go to the config and look at the sympte on the sympte config and nothing shows on the virtual dj
i hear the tone from the deck on my external mixer but nothing
what do i use for the timecode setting 1000 or 2000 hz
tryed diffrent ones but nothing moves
Posted Mon 09 May 11 @ 9:22 pm
ok i did another test i press play on my 3700 with the sympte cd that came with the virtual dj and it still doesnt work so i think now that it may be my virtual box but i play a music cd and it goes through i hear it threw the mixer but i also hera the sympte tone on the mixer ill try new cables
Posted Mon 09 May 11 @ 10:02 pm
