I just switched PCs to a Dell Lattitude E6410. I set up the ASIO driver for the Numark and all seemed good in initial testing. A few weeks later I go to use the setup again and at first the driver doesn't seem to work. It doesn't connect with the Numark. I reinstalled the driver and the connection is made but the sound is VERY distorted (using External Mixer mode). I switched the configuration back to single output (still with ASIO driver) and then back to External Mixer and the output went back to normal. This problem seems repeatable. I did not have a similar issue with my Lenovo Z61P. Any thoughts on what the issues might be?
Posted Sun 19 Dec 10 @ 9:03 pm
