well after months of deciding,i'm hooked on virtual dj,so is the electronic delivery ok?or worth having discs sent?also as the program updates are they free?ie is it a one off payment?also im using m audio exponent usb controller,i'm guessing it works ok with that?what can i expect with pro?are there more features etc?can u save samples etc?many thanks in advance
heres what ive acheived with the free version so far....
http://www.youtube.com/watch?v=tE2HpGcCkg8
Posted Sat 18 Dec 10 @ 10:33 am
Dude across the board just take the plunge. A lot of digital djing is trial and error(actually messing with technology, period). You will have issues here and there but all the issues I've had have been easily solved. Digital download is fine. Free upgrades for life. I've been VDJ for about 5 yrs now. Topnotch software, dude. Check out my Ustream with VDJ----http://www.ustream.tv/channel/staleyaic-from-twilight-town
Posted Sat 18 Dec 10 @ 11:08 am
If you are planning on also buying a controler such as Hercules, or numark, then I'd suggest doing that first, since with that you can get a good discount for VDJ, if you buy VDJ first and then go for one of those, welll, no discount.
Also, yes, do it, VDJ is the best.
yes you can save samples, yes you can pretty much custumize it to no end. Tons of skins, great for video mixing and now with the available iPhone app!
Posted Sat 18 Dec 10 @ 2:05 pm
Samples can only be loaded and saved in the full VirtualDJ Pro, but as above, you can upgrade at a discount from the free limited Hercules DJ Console Edition of VirtualDJ included with the console.
https://virtualdj.com/products/comparison.html
Posted Sat 18 Dec 10 @ 2:21 pm
-Post Deleted (apparently there is no option to actually delete posts, something almost any forum has)-
Posted Sat 18 Dec 10 @ 10:22 pm
emergency ! nlu w/ panties in a bunch !
Posted Sun 19 Dec 10 @ 4:16 am
thanks for all the replies i already use an m audio xponent,whats the premium membership about?i intend on buying pro,does that come with it??
Posted Sun 19 Dec 10 @ 8:15 am
bump
Posted Mon 20 Dec 10 @ 2:22 am
Premium Membership gives you access to over 8 million songs that you can stream directly via the Internet.
Please see https://virtualdj.com/products/membership.html for details.
Pro does not come with Premium Membership - It is a completely separate and optional service.
Posted Mon 20 Dec 10 @ 6:33 am
@ darkdezigns, using Premium Membership is an ideal way of building a good music library especially if you are just starting out in the digital field.
@ 8-BitAce, just remove your text from a post and replace with "edit" thats what I normally do if I decide to remove any comments, lets people know you would rather have deleted post.
Posted Mon 20 Dec 10 @ 12:14 pm
