CAN YOU PLEASE GIVE ME THE CORRECT CONFIGURATIONS FOR VIRTUAL DJ ON A PC WITH WINDOWS VISTA 64 BIT OPERATING SYSTEM 2 DENON 3700 *PLEASE INCLUDE ANY SETTINGS THAT NEED TO BE CHANGED ON THE DENONS IF ANY TO MAKE IT FUNCTION PROPERLY WITH VIRTUAL.
Posted Fri 17 Dec 10 @ 7:48 pm
Settings for the S3700 (go into the preset mode)
MIDI CHannel for both = 1
Unit No for both = ALL
Jog Pulse for both = 1480
Latest Firmware = v2020, get it here:
http://denondjforums.com/forum/index.php?f=50&t=13685&sid=b5abbde7376282eec355a92422d68162&rb_v=viewtopic
64-bit ASIO Driver is found here:
http://denondjforums.com/forum/index.php?f=50&t=11486&sid=b5abbde7376282eec355a92422d68162&rb_v=viewtopic
Posted Sat 18 Dec 10 @ 8:40 am
we got 99 decks ......
Posted Sat 18 Dec 10 @ 9:06 am
can someone please tell me where I can find the mapping commands for the 3700...I got it all hooked up but it would be nice if I had a picture to know what buttons do what.
Posted Sat 18 Dec 10 @ 1:54 pm
I dont know of one, but most of the keys do the same function as normal CD mode.
Posted Sun 19 Dec 10 @ 10:20 am
Its a good idea to do something like this for our users. I have a 3700 and I can make an image like this if you like.
Posted Sun 19 Dec 10 @ 10:49 am
Here is part 1 of 2. I will post the shift mapping later. This map shows VirtualDJ mapping using the default settings.
Posted Sun 19 Dec 10 @ 11:35 am
