I've taken the plunge after 4 years, to update my laptop. Which files will need to copy / re-install on the new machine. I also have DMC2 controller.
Posted Tue 14 Dec 10 @ 3:32 pm
Copy the C:\Documents and Settings\Username\My Documents\VirtualDJ folder across and that should do it.
You will have to reinstall VDJ in the new machine then overwrite with the VirtualDJ folder from the old machine.
I take it you are using Windows?
Keith
Keith
Posted Tue 14 Dec 10 @ 3:36 pm
Yes Keith, windows 7 home premium 64 bit
Do I need to do anything for the DMC2 controller ?
Posted Tue 14 Dec 10 @ 4:28 pm
the DMC2 is just plug and play. no drivers needed.
Posted Tue 14 Dec 10 @ 5:58 pm
