I have a DJIO sound card and when trying to configure VDJ 7 and the mic I get the error message Not Enough Channels. I have tried to configure in the advanced config and same error message. I have updated the driver and still the same message. Is there a way to configure it to work within VDJ? It works fine out of VDJ 7 but will not work when configuring in VDJ 7. Thanks for the help in advanced.
Posted Tue 14 Dec 10 @ 12:06 pm
what way is your configure mate...
sure its ....inputs...none
outputs...headphones---------channel1/2 decks....3/4 headphones/mic.
soundcard.....asio--------------hercules rmx
never used djio for my mics as there is no control ie high low ect.....
remember alway click apply for setup
Posted Tue 14 Dec 10 @ 1:07 pm
configuration on VDJ:
inputs: none
outputs: headphones-------Master 1&2decks Headphone 3&4 no option for mic on this one
sound card: Asio
inputs: none
sound card: Asio
Posted Tue 14 Dec 10 @ 1:18 pm
as i said mate that was my set up as never used djio for mic..............try other way around 3/4 decks....1/2 headphones as headphone are same jack input on djio...
wish i could help more mate...i still us djio for backup mac laptop...
did you send email to hercules or try on their site for technical help
Posted Tue 14 Dec 10 @ 1:26 pm
Thanks for your feed back appreciated it much..
Posted Tue 14 Dec 10 @ 2:11 pm
