if my laptop is connected...the hum sound start...once disconnect it...that sound it's gone, the any way to solve this without disconnect my laptop.....thanks.
Posted Sat 11 Dec 10 @ 8:04 am
Check your laptops ground or buy some ground loop isolators.
Huey
Huey
Posted Sat 11 Dec 10 @ 8:17 am
I agree...Ground Loop Isolators are the way to go. Sooo much interference from laptop power supplies (Most of them, anyway), those little isolators are a lifesaver!
Posted Sat 11 Dec 10 @ 9:10 am
If you laptop plug has 3 prongs you might have to buy a adapter to bypass the ground. it takes the three prong to two.
Posted Sat 11 Dec 10 @ 4:58 pm
You have to be careful with that, because a power surge could damage the computer...That's a "quick fix", but the isolators should be used.
Posted Sat 11 Dec 10 @ 7:28 pm
thank' everybody i bought the isolator and that hum it's gone forever
Posted Sat 11 Dec 10 @ 7:40 pm
