I cannot get smart loop to work, lock on or off it just does not work. Loops end up where ever. Is there something in the setup that needs tweaking to get it to beat match?
Need a fix.
HW: Dell Studio 1745, i7 720 core, 6GB RAM, Echo Indigo DJx sound card.
OS: Win7
VDJ 7.0 Pro (b342)
Need a fix.
OS: Win7
VDJ 7.0 Pro (b342)
Posted Fri 10 Dec 10 @ 9:48 pm
same problem here!!
Posted Tue 06 Sep 11 @ 8:26 pm
smart loop only makes the loop size perfect when using loop in and loop out, It wont reallign the loop position on the beat. I have made a request with a possible solution in the wishes forum with no reply, so hopefully the feature will be in the next version.
Posted Tue 06 Sep 11 @ 10:42 pm
