Hello i can't recording with Vms4 with vdj7 pro please help... thx
Posted Tue 07 Dec 10 @ 8:52 pm
Read this guide first (bottom part).
https://virtualdj.com/homepage/djdad/blogs/4316/VMS4_Setup_Guide.html
Posted Tue 07 Dec 10 @ 9:16 pm
HI Dj Dad,
I have set up my config as the diagram shows, which midilog line should i connect the rca booth output too?
I noticed as well the my sound is now distorted.
Cheers
Graham
Cheers
Graham
Posted Wed 08 Dec 10 @ 2:21 pm
You should conect the booth with Midilog1 Line Input. All midilogs are set to USB.
Distortion? When you record, or just with that setup?
Posted Wed 08 Dec 10 @ 6:11 pm
I have the same problem. When I use the record loopback option at the advnaced config, my sound becomes disorted,scratschy.. Is there a way i can solve this?
Posted Mon 31 Jan 11 @ 11:05 am
I'm trying to record an mp3 or a CD of some of my mixes, but (and I know this sounds amateur) I can't seem to get it right. I followed the advanced config noted in the above message, but perhaps I do not have the proper cables, etc. I really don't know and if someone could walk me through all the specifics as if talking to a day-one beginner w/ the VMS4, and dj'ing itself, that would be fantastic. Thanks!
Posted Sat 05 Feb 11 @ 9:06 pm
